DRO color via Macro
DRO color via Macro
Postby vitber » Fri Nov 27, 2020 8:22 am
it is possible to change the color of the font in DRO using a macro?
vitber
Re: DRO color via Macro
Postby dezsoe » Fri Nov 27, 2020 8:55 am
No. The colors are defined in the screenset file when you build the screen.
What do you want to do with changing colors?
Postby vitber » Fri Nov 27, 2020 10:07 am
as soon as the machine coordinates are on, X, Y and Z DROs show in different colors
vitber
Postby dezsoe » Fri Nov 27, 2020 10:35 am
So you use the old screenset. That has light background, so you can make LEDs that are transparent when off and cca. 25% opaque when on with some color. Place the LEDs over the DROs, and set LED numbers to 62. You'll get a colored background for the numbers when machine coords are shown.
