Help with very basic macro - declaring a bool
Postby MattTheNoob » Sat Sep 05, 2020 7:47 pm
In this macro loop below, I can't seem to declare the boolean "spindleFaultEnunciated" without setting it to a value... but setting it to a value every time the loop runs isn't what I want. The way it is shown below throws a "Use of unassigned local variable 'spindleFaultEnunciated' error.
If I change the declaration to "bool spindleFaultEnunciated = false;" or true, I don't get an error, but it messes up what I'm trying to do. I want to Add the status message just one time... not every time the loop cycles.
I know this is really basic and I'm doing something foolish. I promise to smack myself in the head when you point out my mistake. ;)
//   Macro execution starts here
   bool spindleFaultEnunciated;
   if (AS3.GetLED(349))         //Modbus Word 3, Bit 1, Spindle Fault from PLC
      if (spindleFaultEnunciated == false)
         exec.AddStatusmessage("Main Spindle VFD Fault");
         spindleFaultEnunciated = true;
      else
If I try to declare it in line with "If (bool spindleFaultEnunciated == false)", then I get this mess of errors.
CS1525 | in line: 36 | error text: Invalid expression term 'bool'
CS1002 | in line: 36 | error text: ; expected
CS1525 | in line: 36 | error text: Invalid expression term ')'
MattTheNoob
Bostomatic 405 with updated controls... now entering Rev.2
UC300eth-5lpt, ModBus talking to Click PLC, Arduino Gecko servo monitor
Total UC noob.
MattTheNoob
Re: Help with very basic macro - declaring a bool
Postby dezsoe » Sat Sep 05, 2020 10:35 pm
You have to declare your variables that you need in every cycle in the #Events section as static. See this topic.
Postby MattTheNoob » Sun Sep 06, 2020 3:18 pm
That does the trick!! Thank you very much!
         exec.AddStatusmessage(DateTime.Now.ToString("HH:mm:ss tt")+" Main Spindle VFD Fault");
      if (AS3.GetLED(217)==false)         //check if Feed Hold is active
         AS3.Switchbutton(true, 523);   //turn on feed hold
      else
Thread.Sleep(100);
#Events
static bool spindleFaultEnunciated=false;
MattTheNoob
Total UC noob.
MattTheNoob
