Tool height Setting Macro
Re: Tool height Setting Macro
Postby ThreeDJ16 » Sun Sep 08, 2019 3:35 pm
ger21 wrote:It's VB.NET, so the functions are the same, but the syntax is different.
If you've programmed in VB, but not VB.NET, you may struggle with the syntax.
Here are two examples that do the same thing.
VB
#VB
MessageBox.Show("VB")
dim xval as double
xval = AS3.Getfield(226)
MessageBox.Show(xval)
If xval =0 then
MessageBox.Show ( "X axis is already at zero.")
Else
AS3.SetField(0, 226)
AS3.Validatefield(226)
MessageBox.Show ( "X axis reset to zero.")
End If
C#
MessageBox.Show("C#");
double xval;
xval = AS3.Getfielddouble(226);
MessageBox.Show(Convert.ToString(xval));
if (xval == 0)
MessageBox.Show("X axis is already at zero.");
else
AS3.Setfield(0, 226);
AS3.Validatefield(226);
MessageBox.Show("X axis reset to zero.");
Yup, totally missed that...LOL. No VB.net here....thanks for pointing that out. I'm already started down the C# rabbit hole, no point in heading down another.
ThreeDJ16
Postby xillianto » Mon Aug 10, 2020 9:37 pm
Did you manage to get this script done ? I would love a copy of the macro to measure and store tools as i also just manually change the tools on my ATC spindle for now.
xillianto
Postby ThreeDJ16 » Mon Aug 10, 2020 10:07 pm
xillianto wrote:Did you manage to get this script done ? I would love a copy of the macro to measure and store tools as i also just manually change the tools on my ATC spindle for now.
Nope. The new version released somewhere around the time I was doing this and it just got too frustrating trying to integrate. I'm no programmer, so isn't worth all the effort to learn just to make some type of tool measure with a basic tool change integrated. Would be nice for some basic function to be in the probe screens.
ThreeDJ16
