Macro Wizard Code Snippet >> Checkboxes
Postby Robertspark » Wed Jan 16, 2019 10:17 pm
One of a group of example components that was going to put together as Macro Wizard Code Snippets
This one is for checkboxes.
Basically save it as a macronumber file of your choosing (such as M10001.txt) and run it via the mdi.
Two checkboxes will popup on a form, with a "Post G-Code" button.
tick box 1 and it will enable box 2....
you can run any code and it will post the gcode to the Codeview window.
I'm going to add a series of these to the Macro manual, hopefull with some useful events (such as mousehover etc)
// ##  CheckBox Wizard Example, M10001
//Set up the form for Wizard
MyForm = new Form();
MyForm.Size = new System.Drawing.Size(1200, 750);
MyForm.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen;
MyForm.Text = " UCCNC xxxxx Wizard vx.xxxxx ";
//((System.ComponentModel.ISupportInitialize)(this.numericUpDown1)).EndInit();
//Define the objects on the form
         // checkBox1
            checkBox1.AutoSize = true;
       checkBox1.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            checkBox1.Location = new System.Drawing.Point(61, 25);
            checkBox1.Name = "checkBox1";
            checkBox1.Size = new System.Drawing.Size(80, 17);
            checkBox1.TabIndex = 0;
            checkBox1.Text = "checkBox1";
            checkBox1.UseVisualStyleBackColor = true;
            checkBox1.CheckedChanged += new System.EventHandler(checkBox1_CheckedChanged);
            // checkBox2
            checkBox2.AutoSize = true;
            checkBox2.Enabled = false;
       checkBox2.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            checkBox2.Location = new System.Drawing.Point(61, 60);
            checkBox2.Name = "checkBox2";
            checkBox2.Size = new System.Drawing.Size(80, 17);
            checkBox2.TabIndex = 1;
            checkBox2.Text = "checkBox2";
            checkBox2.UseVisualStyleBackColor = true;
         // postGcode - BUTTON
         postGcode.Location = new System.Drawing.Point(222, 653);
           postGcode.Name = "postGcode";
           postGcode.Size = new System.Drawing.Size(302, 37);
           postGcode.TabIndex = 20;
           postGcode.Text = "Post Gcode";
           postGcode.UseVisualStyleBackColor = true;
           postGcode.Click += new EventHandler(postGcode_Click);
// Define the Event Handler  (VERY IMPORTANT)
           // Wizard Form
         MyForm.Controls.Add(postGcode);
         MyForm.Controls.Add(checkBox1); //Checkbox 1
            MyForm.Controls.Add(checkBox2); //Checkbox 2
MyForm.ShowDialog();
      //*************** Starting of the Events Section *****************************
#Events
Form MyForm; //This is a global variable, a Windows Form
// DEFINE all of the elements of the Form HERE (VERY IMPORTANT)
      CheckBox checkBox1= new CheckBox();
      CheckBox checkBox2= new CheckBox();
      Button postGcode= new Button();
// ADD EVENTS BELOW HERE:
   void checkBox1_CheckedChanged(object sender, EventArgs e)
   checkBox2.Enabled = (checkBox1.CheckState == CheckState.Checked);
 void postGcode_Click(object sender, EventArgs e)
      string Gcode = "";
 // STARTUP / LINITIALISATION SECTION
      Gcode = (Gcode +  " ( TEST CODE ) " ) + Environment.NewLine;
      Gcode = (Gcode +  "  " ) + Environment.NewLine;
 // BODY  SECTION
      Gcode = (Gcode +  " ( " + checkBox1.CheckState  + " ) ") + Environment.NewLine;
      Gcode = (Gcode +  " ( " + checkBox2.CheckState  + " ) ") + Environment.NewLine;
 //FINISHING SECTION
       Gcode = (Gcode +  ("M30")) + Environment.NewLine;
       System.IO.File.WriteAllText(Application.StartupPath + @"/Example_codes/Test.tap" , Gcode );
     // Load and Run File
       exec.Loadfile(Application.StartupPath + @"/Example_codes/Test.tap");
    exec.Callbutton(402);
// Close the Wizard
MyForm.Close();
Happy coding :geek:
Rob
UCCNC v1.2110 Macro Manual
