Wizard toolpath solutions?
Re: Wizard toolpath solutions?
Postby Vmax549 » Wed Nov 29, 2017 9:09 pm
HI Robert you can still do your thing just use teh onscreen toolpath to display teh pathing. Open your wizard to a page that already has a toolpath window. That is what I do here.
Conversational programing works GREAT with Wizards.
Just a thought, (;-)
Vmax549
Postby Robertspark » Thu Nov 30, 2017 10:59 pm
anyone got any suggestions with these macro wizard forms to limit textbox entry to numeric + decimal point only?
Thanks in advance
{quiet on the forum at present... christmas shopping?}
Rob
UC400eth, UC300eth, UCCNC v1.2105, Neuron Lite.
UCCNC v1.2105 Macro Manual
Postby cncdrive » Thu Nov 30, 2017 11:26 pm
Hi Rob,
Yes, Christmas shopping is ongoing, but it is not me shopping, but customers shopping at us, so I didn't have time to do the shopping yet. :)
Some code for what you want to do with the textbox:
private void textBox1_KeyPress(object sender, KeyPressEventArgs e)
    if (!char.IsControl(e.KeyChar) && !char.IsDigit(e.KeyChar) &&
        (e.KeyChar != '.'))
            e.Handled = true;
    // only allow one decimal point
    if ((e.KeyChar == '.') && ((sender as TextBox).Text.IndexOf('.') > -1))
        e.Handled = true;
Postby Robertspark » Fri Dec 01, 2017 7:23 am
Thanks Balazs
Good to hear the shop is busy, plus you're getting some fallout of the cyber Monday.
Are you going to alpha test the g41/g42 version with users?
Rob
Postby Vmax549 » Fri Dec 01, 2017 2:44 pm
Balazs that trick does format teh data you retreive from teh form. Can you limit what teh form will take when you enter teh value.
Say your input requires 12.345 ( XX.XXX) and you mistakenly enter xx.cat . Can you format teh field to reject teh NON numeric part ??
(;-) TP
Vmax549
Postby dezsoe » Fri Dec 01, 2017 2:54 pm
No, that trick makes exactly what you want. It rejects any keys that are not digits, controls or the decimal point.
Postby Dan911 » Sat Dec 02, 2017 12:24 am
Vmax549 wrote:Balazs that trick does format teh data you retreive from teh form. Can you limit what teh form will take when you enter teh value.
(;-) TP
Hi Terry,
The code Balazs posted won't allow any input but 0-9 and one decimal. For retrieving it will be of no help, you would need a Regex script to remove.
Postby Vmax549 » Sat Dec 02, 2017 6:06 pm
You Guys are correct I have been too long away from C# and UCCNC.
(;-) TP
Vmax549
Postby Dan911 » Sun Dec 03, 2017 12:01 am
I guess the ole saying is true my Dad use to say to me " I forgot what you didn't learn yet"
