macro input Gcode
macro input Gcode
Postby Mindustrys » Tue Apr 12, 2022 3:43 pm
Hi everyone, I'm making a machine that will have to do the same process for its entire life. I'll explain better
I have a cnc router with the work surface divided in two, in the first half there is a mold in which the blank to be machined will be housed, while in the second half I have another mold in which the mirror copy of the previous blank will be housed.
I installed two NO buttons near the respective parts to be machined, the question and one:
can I make one button start Gcode n001, and the other button start Gcode n002?
taking into account that:
- each mold has its respective pneumatic vice which starts at the start of the gcode and stops at the end of the Gcode.
- the Gcode must be re-run immediately when the chosen button is closed.
thank you very much I hope for your help.
Mindustrys
Re: macro input Gcode
Postby A_Camera » Wed Apr 13, 2022 11:55 am
I don't know if you can load and start a G-code file with a button push, but if the code will always be the same, or at least will be used for a long time, then you can write a macro loop, checking button 1 and button 2 states and call the macro code for the pushed button. The macro code can include the G-code necessary to run when the button is pushed. Perhaps there are other ways to this as well, but the answer is yes, you can do that with UCCNC.
A_Camera
